Yar, it lives, but I still have a bit of tweaking to do to get it living strong and healthy it seems.
So far I have about 300 break-in miles on the motor, and I'm concerned about the oil pressure. I'm only hitting 25 psi at 3000 rpms (assuming my gauge is accurate) when hot, and at idle, it's hovering just above the zero mark. Before my rebuild, I was typically at 35 psi or so at the same engine speed. This is with 10W-30 full syn oil in both cases. Only real change I made to the oil system is going from a BB turbo with a restrictor on the oil feed to an unrestricted journal bearing turbo. Other than that, I used a brand new OEM mazda oil pump.
It would be simple enough to stick a restrictor on the turbo oil feed to gauge that effect. Any suggestions on a "safe" size restrictor that I could run long term, or would I need to get my oil pressure up quite a bit higher before I could restrict the feed without starving the turbo? Other than that, I'll probably swap out for 10W-40 oil.
As an aside, I just recently read of a company that does a modification service to the stock oil pump--ceramic coated internals for longevity and to tighten up the clearances, and replacing the internal pressure regulator with an adjustable external one. Wish I had heard about it sooner because I would've gone for that in a second. Now I'm stuck pulling the tranny and tearing apart a bunch of the bottom end if I want to upgrade the oil pump.
