What gauges?
doh... keep forgetting you're rocking the MS6 and not a MS3. If it has a factory wideband, awesome, but I was under the impression that neither did.
A
aviateur
I've read that the MS3 has a factory narrowband AND wideband O2 sensors :)
Well, I finally got it figured out:
I'll be running a vent pod for boost immediately, then after some engine mods I'll run the center dash pod to hold AFR/water temp/oil pressure.
If needed I'll run a scan gauge tool like the Dashhawk after all that, but I wouldn't need to use it yet.
