Suspension Upgrade Needed!
dirtyd
The MS camber kit isn't adjustable, FYI. It probably won't really be an issue, but if you're going to spend the money, getting a set of adjustable ones makes a lot more sense, IMO.
Yeah, but it says they are made to adjust for lowered speed3s so I figure they'll be okay. I already have some negative camber right now in the rear so I'm not too worried. Unless its like balls out negative camber. Then I'll be a sick puppy.
The MS camber kit is designed for the specific drop the MS coilovers provides... I'm fairly sure.
In any case, it's really probably not a big deal... just saying.
And even if it is a catalog part, keep in mind they'll order the wrong one anyway.
stp
Ah thanks. I'll shoot Jeff an email. I have Koni Yellows going in with stock springs. Wasn't sure if the big name shops would be able to work with it.
