It hasn't done anything other than idle yet. Trying to make it run right on idle before I drop it back on the ground lol. I tried running the Autotune program on the ECU, but it didn't seem to want to lean it out.
And the spark plugs got a bit wet and I think they got messed up and aren't sparking hot/consistantly enough to run right. Because I tested the compression and I tested the spark and all four a lighting, but maybe not at 100%. So once I throw the new plugs at it tomorrow we will see if at least the idle smooths out and then we can lean it out.
