Do you need new fuel pump internals?
Finally got around to installing and datalogging a bit with mine, and wow did I find some pretty amazing stuff. I tried to keep the variables here as similar as I could, so when driving to a buddies place to install the internals I did a 3rd gear log, and did the same as I was leaving. All mods in sig are used in these logs.
It does look like I encountered heatsoak on the first log, which will definitely skew the results here, but I tried as best I could.
OEM internals:
KMD v2 internals:
Glad to see very little knock, AF/R's are solid, and LTFT's are spot on.
This is on an OTS AP map as well, but the 16th revision.
Wow, boost spike + plumetting fuel pressure is a bit scary. But the AFRs look spot-on during both pulls, so that's good.
