Aeroforce Gauges for the MS3/MS6
SHift Light ftl, but it does look kind of nifty.
Too much money for a glorified OBDII reader though, way too much...
EGT, oil pressure and temp, a/f ratio, and boost would be nicer.
It reads boost and A/F, doesnt sound like it does oil pressure or temp which kinda sucks.
sure it does, but its a/f narrowband on 'n off, what good does that do? correct me if i'm wrong, but the MS3 doesn't come with a wide band...
narrowband A/F > nothing. Especially if it can properly read an aftermarket wideband sensor.
Also, being able to view PCM data in a standard gauge format would be nice. Personally, I would view that as a supplement to standard gauges, rather than a replacement, since, unlike other scangauges, this one will integrate nicely into a gauge pod. Sure, you're always going to want to have boost and AFR handy, but being able to select from all that other stuff on the fly would be kinda handy.
I was under the impression our cars had wideband from the factory, is that not true? If it does and the gauge could read that, it would be pretty handy. Not saying its the replace all gauge, but it is pretty damn handy, and the fact that its plug in play is nice for those non-DIY'ers.
Z
Z-licious
Is there a mount I can buy that would let me mount it in the vent as shown in the picture? If not, then I have a good excuse for not buying this.
