$800 to spend
Dinos Speed6
I got about $800 to spend on my car in June, its all stock what now what do you guys recommend for the best bang for your buck. Thanks
My stock response to this question is almost always "suspension upgrades". It's a little bit of a different story when there are well-established tuning systems out, but it's still one of the most cost-effective performance mods you can do.
I'd say depends on your goals for the car. If your going to auto-x it / track it suspension and brakes might be the way to go. Otherwise what others have said Tuning would probably be the way to go. My plan is tint, possibly an intake, then tuning.
I dont know if you are worried about warranty or not, but messing with the suspension while in the 3/36 period is a good way to void it. With something like an intake, you can easily remove and replace it. Or, if you go MZspeed its ok.
Dinos Speed6
Shoulda been more specific, Im looking performance wise bang for the buck, its my birthday in June so i thought I would splurge with an extra paycheck I get that month which should be around 800-1200. I was originally gonna get new rims but than I thought I could get some pretty decent performance for that much money and am trying to decide on what to get. I was thinking CAI, BOV, Test Pipe and boost gauge...but am open to different ideas
T
Turbotalon1g
Boost Gauge for sure, then intake, Test pipe (a universal item), BOV.
Maybe wait a little or perhaps by then LSE will have Mazda performance bolt-on products for you all.
Drop the BOV.... factory will do fine until you start to turn up the boost, unless you really want the sound. I'd say CAI/DP/test pipe/boost gauge myself.
Dinos Speed6
Yea Ill probably drop the BOV, I think right now Im going CAI, test pipe, boost gauge, and exhaust(gettin hooked up with exhaust) what size exhaust should i go? 3"?
Depends. Given the fact that our turbos are so effin dinky, you may run into boost creep. But hell. Go 3inch, and get a boost controller so you can turn it down some and get a more consistent flow. Or go 2.5DP 3inch back.
Dinos Speed6
Hmmm I might have to invest in a EBC then also. I dont plan on touching the DP or turbo for a while yet, just tryin to do the simple bolt on for now. Anyone try the new motor mounts out?
