P
pingwin77
This gun has only been used once and it was great. I have 2 of these and have decided to sell one to help with my mod budget. This gun can fire up to 30+ balls per second (bps) thanks to the new rocking trigger frame that kingman put on it. There are 4 firing modes:
1. Semi-Auto: Just pull the trigger and it fires, no need to pull a bolt or crank on a pump. This is the mode that will give you 30+ bps. The gun will shoot as fast as you can pull the trigger.
2. 3 round burst: Just hold the trigger and the gun will shoot 3 balls at a time. You can adjust the rate of fire from 6bps up to 13 bps.
3. 6 round burst: Same as above with 6 balls instead of 3.
4. Full-Auto: Just hold the trigger down and the gun shoots. Also adjustable from 6 bps to 13 bps.
For more information check out the Kingman site http://www.kingman.com/section/emarker/guns/electra_05/index.html
Along with the gun, you get a battery charger, barrel plug, squeegee and hopper.
If you are looking for a great electronic gun, look no further.
