So here's my situation:
Linksys E3000 router is located on the main floor (want to keep it there for ethernet connections to AV devices). Wireless signal is excellent everywhere in and around the house, but out in the garage apparently going through 2 layers of stucco and the associated metal caging is too much. It also doesn't help that there is a brick chimney situated perfectly between my preferred spot for the router and the garage.
The netbook only has wireless-G, and I was able to take the situation from not even seeing the router to getting a very weak signal by tweaking the 2.4ghz radio settings and turning off the power save mode on the netbook wireless card. But I don't have a strong enough signal to reliably stream music (which is my minimum requirement).
I have tried moving the router around (out from behind the chimney, up higher, and closer to the garage) which gets me an acceptable connection, but long-term it would require me to be running ethernet cables all over or drilling a bunch of holes in my kitchen and living room.
How much of a difference would I see by just adding a wireless-N adapter (with external antenna) to the netbook? Unfortunately the router does not have an external antenna. You can mod it, but only the 5ghz antenna can be upgraded without soldering on the circuit board... which I'd rather avoid.
tl;dr all else equal, will switching to a wireless-N adapter give a significant improvement in range?
