$old/$old/$old!!
Different bolt pattern. Plus spacers are BAD.Those wheels are pretty high offset, you could probably get adapters for the charger if you really wanted. Rather than buying a while new expensive set
Just an FYI I'd advise you to purchase an add-a-MINIfuse and 7 feet of 3/16" vacuum line - what they supply you is junk. You'll also need to extend the wires on the gauge.I'll take zee Boost Gauge, nom.
