mOjO
Member
Over The Air (OTA) HD signals are better than what you receive from your Cable or Satellite providers. Why? Cable companies will compress less popular HD channels signal to retain a higher fidelity for the "popular" channels. Sometimes they will broadcast in 720 instead of 1080 "HD". Also, much of the signal losses found from a cable setup won't be found in an antenna based system. Don't be fooled by your providers. For most people, the highest quality HD signals are FREE.
Here is a great link to find out what TV stations you are likely to receive at your home: http://tvfool.com/index.php?option=com_wrapper&Itemid=29. It will also help you pick out what type of antenna you need (set-top, attic, roof) and what sub-type (full directional, semi-directional, omni-directional)
I'm trying to source some recommendations on some makes and models of antenna that would work well. I'll post these up when I get them.
