I bet my battery is smaller than yours...
BP_Festy
Do you see it? Look close.
Yep, now I can put on the Protege intake tube. That also means I can put an air filter on too! ha ha ha
The battery is out of a jump pack. I made a tray out of aluminum and TIG'd it together. Turned out pretty good. The bad part is it's negative 5 right now and my car is running on E85 so it takes awhile to start. It will be fine when it's warmer out.
Is that a motorcycle battery? LOL, its tiny!
I'd be interested to hear some more about your experience with E85, apparently its 110 octane or something crazy? I know there are some people out there getting some insane HP numbers with it.
Not to get off topic, but be careful calling it 110 octane. The fuel is a much higher octane rating, but you need much greater amounts of the fuel. So, higher flow pump, higher flow injectors, sometimes even a higher flow fuel rail.
As for the battery, good work. You see a lot of drag guys go to something like that for weight reduction. Just make sure you have enough CCA (Cold Cranking Amps) if you are gonna use it through winter/cold weather.
Just to expand a bit...
Practically and technically speaking, octane rating is just describing the ability of the fuel to resist knock in a test engine.
But, ethanol has something like 2/3 of the energy content per volume that gasoline does. So, ethanol may have anti-knock properties equivalent to 110 gasoline, but you'd need the capability to flow (and ignite) about 50% more fuel than if you were actually running 110 gasoline.
On topic: That's a tiny-ass battery! Are those jump-packs rated for the kind of charge/discharge loads a normal car battery would see? Wonder how long it'll last under that kind of duty.
Also, I'm, just curious what made you opt for using a teeny battery as opposed to, say, relocating to the trunk or something. Weight, I'm guessing?
I would imagine cost is also a factor. Those small batteries, in addition to the size and weight savings, can be had for about 1/2-2/3 the price of a regular Interstate or Die Hard batter.
Good info to know!
Out of curiosity, what did you do to the engine to cope with e85? That stuff has always intrigued me.
Also, that is one wicked tiny battery. I love homebrew mods like that.
Huh. Interesting stuff. Looks like it's going to be massive amounts of fun when it's together. Hope to see it some time.
BP_Festy
He has much larger than stock injectors (220 vs. 160's I think) on it... That is all.
250cc vs 180cc
If I really CONVERTED it I SHOULD upgrade the pump, which I'll be doing for the next motor, and replace the lines. In all honesty an optimized fuel map wouldn't be bad either.
BP_Festy
Yep. It runs well. As well as it did on gas that's for sure. I haven't been able to keep my foot off the throttle to get any gas mileage figures.
