FrotchRocket-FC
Trying to clean up the garage and want to sell locally first, heres the list:
2x Yokohama 225/50/16 tires - $40 for both
S4 "Sport" style spoiler - $50
S4 NT/MT Driveshaft - $30
S4 NT used clutchmasters clutch and pressure plate - $20
S4 NT flywheel - $20
S4 NT/MT Starter - $20
Flash-To-Pass lenses, immaculate - Make Offer
4x Exel 5x114.3 17" wheels wrapped in Nankang 215/45/17, good tread and 1 nick on 1 rim - $300 OBO
4x Nankang 215/45/17 Tires, pretty good tread - $75 for all 4
Racingbeat S4 NT/MT presilencer - Make Offer
Pics can be seen at: http://s153.photobucket.com/albums/s236/frotchrocketttt/
The yokohamas are going for cheap because they were mounted on the FD wheels I bought, but I went for some new BF GForce tires, they held air and have good tread, but I really cant say they are 100% perfect since I did not drive on them. The clutch/pressure plate have about 10k miles at most, intended as a cheap temp fix if somebody needs it. The starter is the original and was pulled from the car around 40k miles and worked when pulled, but i'm not sure exactly how much longer it will last. The FTP's have absolutely no chips, cracks, or fading. I don't really want to let them go, but if someone makes a reasonable offer I will let them go. Lastly the racingbeat presilencer has one of the front bolts partially broken off where you cant fit a nut on, with a gasket and a bit of that high temp. gasket maker I didnt notice any leaks. If there are any questions, contact me through email at jmauli@gmail.com, I will try to get back as soon as I can. If nothing sells within a few days, I will then post on the other major forums, first come first serve (exept on offers).
