FS: '04 Mazda 6s Key Fob
hashish
Hey guys I just found my key fob when going through my old stuff and I wanted to offer it up here. I can't test because I no longer have my car, but it definitely worked when I did have it. Looking for $10 picked up near Lake Calhoun.
Visteon Model: 41846
FCC ID: KPU41846
Let me know if you are interested.
hashish
Here are the instructions for programming the fob:
Open driver door,
Press lock and unlock using door switch
Put key in ignition, turn to on position then off position 3 times leaving key in at the off position
Close door and open three times leaving door in open position
Doors will lock then unlock to confirm ECU program mode
Press any button on remote twice, locks will confirm by locking then unlocking, your done remove key from ignition and doors will lock and unlock couple times to confirm exit from ECU program mode.
