Android Rooting and ROMs, etc...
I jumped ship from the iPhone4 to a Motorola Atrix over the weekend. I started doing a little bit of research into rooting it, but haven't gotten to far into it yet. I know a few people have done it to their android devices. Do you guys have any advice or tips for the process? Can anyone give me a super quick overview of what the deal is?
Well XDA Developers forum is going to be your best bet for information. Rooting and Rom's are kind of two separate things - root is going to get you access to run more apps and load roms, custom themes, etc. Depending on the device it can be as simple as a single app you load and run that provides root access, or sometimes you have to run apps / commands / etc through the command line using the Android SDK. I'd try and find some info on XDA around what is available for your specific phone, usually a phone will have its own section and often instructions for rooting. Make sure you read a TON and fully understand what version of Android OS you are on, make sure what you are trying to load is compatible with that version, etc. Sometimes you can only root certain versions, or if you flash to a newer version you can't go back, etc.
As for ROMs, sometimes they will unlock hidden features or functionality, improve performance or battery life (or both), etc. I ran a few on mine till I settled on one that seemed to offer decent asthetics as well as performance / features. Main reason I rooted was to be able to run apps I otherwise couldnt run (like mobile hot spot apps).
I think there is another thread around here with good app idears.
1Kris06
MAD LIGHTS YO
i got nothing on rooting and/or roms. but applanet is what i use 99% of the time to find apps. Everythings free, so you could potentially find full apps (vs limited feature ones) for free to try and then buy them through the app store if you so desire.
Rooting is essentially "unlocking" the OS. ROMs are new UI/OSes that you install, packages of apps and changes to android, right?
It sounds like the method of unlocking and which ROMs are available is phone dependent.
Is "sideloading" a method for installing apps NOT on the marketplace?
micahlarson
right, not all changes require root access though.
Correct
