From this thread: http://forum.mazda6club.com/index.php?showtopic=74700&st=0
TSB: 05-003/07
2006 - 2007 MAZDASPEED6 - CLUTCH PEDAL IS DIFFICULT TO OPERATE
2006 - 2007 Mazdaspeed6 vehicles with VINs lower than JM1GG****7*107613
When releasing the clutch, the height of the pedal where the clutch starts to engage is higher than other vehicles making a smooth engagement difficult. Higher pedal pressure is required to depress the clutch pedal at the point of clutch engagement.
The following mass-production changes have taken place:
Feb. 21, 2006 - Improved clutch pedal characteristics.
May 26, 2006 - Improved clutch cover release load characteristic.
July 1, 2006 - Improved clutch disc cushion deflection.
Type A Vehicle
(VINs from JM1GG******100001 - 106359)
Type B Vehicle
(VINs from JM1GG******106360 - 107613)
Clutch Pedal Type: "Pre-Modified"
Clutch Pedal Type: "Modified"
1. Verify customer concern that clutch pedal is awkward or difficult to operate.
2. Determine if vehicle is Type A or Type B:
If Type A vehicle (with Pre-Modified Clutch Pedal): Replace clutch pedal, clutch cover, and clutch disc assemblies with modified parts according to Workshop Manual (section 05-10 CLUTCH PEDAL REMOVAL/INSTALLATION A26MX-R).
If Type B vehicle (with Modified Clutch Pedal): Replace clutch cover and clutch disc assemblies with modified parts according to Workshop Manual (section 05-10 CLUTCH UNIT REMOVAL/INSTALLATION A26MX-R).
3. Verify repair.
PART(S) INFORMATION
CAUTION: * The modified Clutch Cover Assembly and Clutch Disc Assembly must be replaced as a set.Part Number
Description
Qty.
GP4L-41-300A
Clutch Pedal Assembly
1
L304-16-410A
*Clutch Cover Assembly
1
L304-16-460B
*Clutch Disc Assembly
1
P017-27-421A
Driveshaft Retaining
2
T060-26-169A
Tie-Rod Nut Lock
2
GJ6A-33-023C
Lower Arm Bush (Front)
2
GJ6A-33-024C
Lower Arm Bush (Rear)
2
A601-17-117
Drain and Filler Plug Seal
2
L3A1-40-581
Seal Ring
1
LN01-27-3A2
Ring "O"
1
LN01-27-3A3
Oil Seal
1
WARRANTY INFORMATION
NOTE:
This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
Additional diagnostic time cannot be claimed for this repair.
I've never liked the clutch and have never made any changes to it. I may have to talk with them on this one.
TSB: 05-003/07
Type A Vehicle
Type B Vehicle
3. Verify repair.
PART(S) INFORMATION
Description
Qty.
GP4L-41-300A
1
L304-16-410A
1
L304-16-460B
1
P017-27-421A
2
T060-26-169A
Tie-Rod Nut Lock
2
GJ6A-33-023C
2
GJ6A-33-024C
2
A601-17-117
2
L3A1-40-581
Seal Ring
1
LN01-27-3A2
Ring "O"
1
LN01-27-3A3
Oil Seal
1
NOTE:
