Tires/Wheels - Body Vibration/Steering Wheel Shimmy
    02-004/05
    2000-2006 MULTI-MODEL - BODY VIBRATION OR STEERING WHEEL SHIMMY
    Note : This bulletin supersedes the following TSB(s): 02-001/03. Please update your records accordingly.
    BULLETIN NOTE This bulletin supersedes the previous bulletin 02-001/03, issued on 02/24/03.
    The APPLICABLE
    MODEL(S)/VINS and DESCRIPTION have been revised.
    2000-2003 Protege
    2002-2003 Protege5
    2000-2002 626
    2000-2002 Millenia
    2000-2006 Miata
    2004-2006 RX-8
    2004-2006 Mazda3
    2006 Mazda5
    2003-2006 Mazda6
    2000-2006 MPV
    2001-2006 Tribute
    2000-2006 B-Series Truck
    If a vehicle has body vibration or steering wheel shimmy while driving, and the root cause is determined to be tire balance, re-balance the tires using a Hunter GSP 9700/9712 balance machine. When using the Hunter GSP 9700/9712, be sure to use the following centering cones and cone/wheel set up listed below.
    Using the appropriate centering cone ensures that the wheel will be properly centered to the centering cone.
    To find the location of a GSP 9700/9712 near your dealer, visit Hunter's web site at www.gsp9700.com and click on "Find a GSP9700 Near You".
    1. Select the appropriate centering cone and use the following setup:
    ^ 4-stud wheels - use Hunter Cone # )51
    ^ 5-stud wheels - use Mazda Required Tool SST # )192-148-2
    NOTE : Wheel balance cones have an ID (inside diameter) of 40 mm which will fit most tire balancers.
