Suspension - Front Suspension Squeaking On Bumps
    TSB: 02-002/06
    2004-2006 MAZDA3
    SQUEAKING NOISE FROM FRONT SUSPENSION WHEN
    PASSING OVER A BUMP
    2004-2006 Mazda3 vehicles with VINs lower than JM1 BK**** ** 483440 (produced before January 27, 2006)
    Some vehicles may exhibit a squeaking noise from the front suspension when passing over a bump at a low speed. This is may be caused by one of the following.
    The front lower arm making contact with the bushing, causing a squeaking noise.
    The fluid in the rear bushing makes an unusual noise.
    2. Replace front lower arm. Refer to appropriate Workshop Manual section 02-13 - FRONT LOWER ARM REMOVAL / INSTALLATION.
    3. Perform toe-in inspection and adjustment. Refer to appropriate Workshop Manual section 02-11 - FRONT WHEEL ALIGNMENT.
