Sigs
Well, bbcode obviously works (see below), but AJ might have tweaked the user permissions and sent something awry. Also, I am all for a 100x500 pixel limit. I hate browsing forums where the average sig is 50 times bigger than the average post.
No clue what you two are talking about, I turn my sigs and avatar viewing off.
If I had it my way we'd all get about 30 text spaces and that's it.
spek1098
yea, I was have problems using frames and a couple other bbcodes
Jesse MS3GT
Querulous
I regret having changed my avatar since its only 50x50 now.. lol
Is my sig easier on the eyes? It used to be huge..
wow I need a sig like that, but with a red 3 instead of white! well and my name lol
You could try uploading the image as your sig instead of linking it. Otherwise, I'm not really sure why it doesn't display correctly.
Earlier, he had it with the img tags, but the tags were just showing up in his sig for some reason. I can't edit sigs anymore, otherwise I would've futzed with it for him...
It is a user group issue. You are in a “New Member” user group until you have 25 posts and then you move into the active member group. In the new member group you don’t have the ability to use any kind of sig except letters. Once you hit the 25 post mark it should switch to the “active/registered” member group witch will let you do anything for your sig (within reason).
Nate
asellus
Member
Well, whatever was done since the time I created this thread fixed it. :p
And no, it wasn't a post count issue, seeing as how I was around 63 posts and experiencing the problem... :|
Yes it was a post count issue. I think the forum hates you cuz your account was tagged and put on notice. I had to release you to the active member group. :)
Your Welcome Champ.
Nate
My personal opinion on the matter is that tall sigs are kind of annoying. You have to scroll past them every time someone posts. If it were up to me, the max height of a sig would be about as tall as the cool transformers thing you have there.
Parnell's (cosmicspd3) is about the perfect size IMO.
Adrian, trim off the top and bottom and you'll be good.
Edit: this is 130px tall but I think it's probably kosher.
