Rally lights, because racecar
Discussion in 'Car Audio, Electronics, & Lighting' started by Cmezz331, Mar 7, 2012.
  1. Cmezz331
    Cmezz331 Member
    im just gonna leave this here.....
    Untitled by cmezz331, on Flickr
    not as jank as you think...
    ps, theyre also going to have a quick detatch system...ill show pics of it when it gets installed
  2. MaxVandervelde
    MaxVandervelde New Member
    It's a lot more sturdy than it looks. for being made of PVC
    Also, Mmmm... Macaroni and cheese.
  3. Cmezz331
    Cmezz331 Member
    mmmmm your tires...
  4. ohsixspeedsix
    Those look pretty dope. You should plasidip the pvc black before you toss em on though.
  5. dmention7
    Yeah, I'll hold any comments until you paint the PVC, and trim the mounting studs for the lights. lol
    But props for DIY!
  6. Cmezz331
    Cmezz331 Member
    All in good time:) it went from "hey this would be cool" to fully done in about 3 hours lol
  7. Big Nate
    PVC is an underutilized materiel if if you ask me. You can make a lot of good stuff out of it.
    Nice looking DIY.
  8. MaxVandervelde
    For most things it's a little too bulky/flimsy/ugly.
    For this it turned out to be perfect. Assuming it stays together XD
  9. mndsm
    Flip the bottom light cages around so the text is right side up. that's gonna drive me crazy otherwise. Props for the build tho.
  10. ohsixspeedsix
    This ^ that was bugging me too
  11. MaxVandervelde
    It's not that easy, the cages and the bottom piece on the base are one piece, so they don't just "flip around"
    Best bet is to cut the logo, flip it, and re set it. Lot of hassle.
  12. escort1991
    escort1991 New Member
    x3
    If you can't just flip them, cut them off and leave them off?
  13. ohsixspeedsix
    Or just put them all on the top.
    EDIT: Or give me the other two to put on my ms6 :D
  14. mndsm
    are the cages integral to the mounting of said lights? If not, i'd say cut the cage off at where the mount plate and the cage meet, flip it, and epoxy it back.
  15. MaxVandervelde
    You can't solve all your life's problems with epoxy.
    ... But yes, I think that's what he's going to do.
  16. 1Kris06
    1Kris06 MAD LIGHTS YO
    Right, because duct tape is the fix all for life.
  17. Cmezz331
    Cmezz331 Member
    There's a little piece that recesses into the mount, that's what the big rectangle near the base is, so we cut the rectang off the bottom, the make a little slit on the top, problem solved. In fact, I'm gonna go doitnow.exe
  18. Cmezz331
    Cmezz331 Member
    So we sheared 2 drill bits completely in half trying to drill through the crashbar, project is indefinitely delayed until we can find a new way to drill through the crashbar.
  19. ohsixspeedsix
    Steel bits?
  20. spek1098
    spek1098 Guest
    Tempered steel bits and an impact drill - sloved
