Plasti-Dip
Discussion in 'Appearance and Body Modification' started by JohnnyT, Jun 20, 2011.
  1. mndsm
    That looks pretty killer.
  2. ohsixspeedsix
    Thank you sir! I agree.
  3. Picklz
    Wow, that turned out quite nice, now I'm not sure if I want to do my aftermarket grill in CF wrap or that stuff.
  4. mndsm
    Both! You could wrap it, and if you get bored, dip it... since the dip would peel right off. Plasti-dip is magical.
  5. ohsixspeedsix
    Matt I would dip it solely for the durability. But also the cost and ease. I also think im gonna clear coat it.
  6. dmention7
    Not too shabby!
  7. ohsixspeedsix
    Sorry to jack your thread JT but I really need opinions on these. I like the look but the finish looks bad when you look closely. What do you guys think? Worth another shot?
  8. AJ
    AJ 110 HP of FURY!
    Really.....?
  9. DrWebster
    DrWebster Guest
    The finish looks decent, but having the one spoke uncoated is pretty wack.
  10. ohsixspeedsix
    Yeah I'm not so sure. It might be a good idea gone bad.
  11. mndsm
    IF you're going to do the one spoke thing, gotta do some odd color. Stock looks kinda like you gave up halfway through. Other than that, I think it'd be worth another go. Maybe spray em all the black and peel the MS logos so that only the Mazdaspeed shows through? I don't know. I like it though, overall.
  12. AJ
    AJ 110 HP of FURY!
    Yeah, I think the color is the ticket, do something wild, see how it holds up at an autox!
  13. ohsixspeedsix
    Is that a yes or a no, AJ? lol
  14. JohnnyT
    JohnnyT New Member
    Well after an exhausting weekend at BIR we got home early enough today that I had a bit of downtime. After a bit of thinking I decided to plasti-dip the extra set of lights I had for the Z06. Figuring black paint allows light to shine through I assumed plasti-dip would do the same. I had much better luck this time around and everything turned out incredible. I'm VERY happy with the results. I didn't clear them and I don't plan to. I figured I'd stick to the flat black theme with the side vents and lower rear fascia.
    Braking still allows plenty of light even during the day
    I got lazy and didn't install the front corner lights or side markers yet but here's how they turned out
    Whatcha guys think?
  15. DrWebster
    DrWebster Guest
    Dude, those tail lights ended up BALLER.
  16. mndsm
    Shits incredible. How many coats did you use on the lights?
  17. JohnnyT
    JohnnyT New Member
    Just one full coat - they were plenty black after that so I had no reason to do any more. Being they're on the back too they shouldn't get chipped up. I'll report back later to see how the fronts are holding up once I get 'em on.
  18. Picklz
    This stuff is really impressing me, I'm probably going to pick some up this week and do my C Mod grill and get that installed on the MS6. Your stuff turned out great JT.
