Navigation System - Displays Incorrect Map or No Map
Discussion in '2007' started by JustROLLIN, Jan 7, 2009.
    Bulletin No: 09-003/08
    Last Issued: 01/16/2008
    NAVIGATION SYSTEM DISPLAYS INCORRECT MAP OR NO MAP AT ALL
    BULLETIN NOTE This bulletin supersedes previous bulletins 09-008/06 issued on 03/17/06, and 09-005/07 issued on 02/15/07. The APPLICABLE MODEL(S)/VINs have been revised.
    Some vehicles equipped with the factory navigation system that have been activated in one location, then transported long distances with the battery disconnected or room fuse removed, may not display a map or may display an incorrect map.
    Customers having this concern should have their vehicle repaired using the repair procedure.
    2. Turn ignition switch to "ON" position and press "OPEN" to open navigation system display.
    3. Select "Agree" and press "ENTER".
    NOTE: Normally the current position screen appears, but the navigation system may exhibit one of the following failures depending on symptom(s).
    - Displays NO MAP in screen (white or blue). Proceed to "A. NAVIGATION SYSTEM DISPLAYS NO MAP".
    - Displays map, but does not display "the vehicle's current position". Proceed to "B. NAVIGATION SYSTEM DISPLAYS MAP, BUT DOES NOT DISPLAY VEHICLES CURRENT POSITION".
    1. Move vehicle outside to open area away from buildings or high walls where GPS is receivable.
    2. Stop vehicle in a safe location, set parking brake, and ensure all doors are closed.
    NOTE: Closing all doors prevents RF interference between navigation system and advanced keyless entry system.
    3. With engine running, operate navigation for vehicle current position" following steps a - m:
    a. Press "Menu Key".
    b. Select "Destination Entry".
    c. Press "Change".
    d. Select AREA (vehicle current position), press "OK".
    e. Select "Address".
    f. Input address of vehicles current location.
    g. Display current location.
    h. Press "Menu" and select "Navigation Set Up".
    I. Select "Calibration".
    j. Select "Position/Direction".
    k. Press "Enter".
    I. Press "OK".
    m. Display MAP.
    4. Wait for a maximum of 20 minutes with engine running and all doors closed.
    5. Procedure is complete when "GPS" appears on screen.
    B. NAVIGATION SYSTEM DISPLAYS MAP BUT DOES NOT DISPLAY VEHICLES CURRENT LOCATION
    3. With engine running, operate navigation for vehicle current position" following steps a - i:
    a. Press "Menu" and select "Navigation Set Up".
    b. Select "Calibration".
    c. Select "Position/Direction".
    d. Press "ZOOM in".
    e. Press "ZOOM out".
    f. Press "ZOOM in".
    g. Press "ZOOM in".
    h. Press "OK".
    I. Press "ZOOM out".
