Keyless Entry - Security Access Procedure
Discussion in '2007' started by JustROLLIN, Jan 7, 2009.
    2004-2007 RX-8, 2004-2007 MAZDA3, 2006-2007 MAZDA5, 2006-2007 MX-5, 2007 CX-7 AND ALL OTHER VEHICLES EQUIPPED WITH EPATS (PATS LOCATED OUTSIDE OF PCM)
    1. Enter security access.
    NOTE: ^ The following screen is an example of 2004-2007 RX-8. All other EPATS equipped vehicles will have slightly different screen text.
    2. Confirm VIN.
    ^ If displayed VIN is not appropriate, choose "NO" and enter a correct VIN on the next screen.
    3. Provide VIN, Part Number, Serial Number, Outcode and Error Control to obtain Incode on the Incode website.
    ^ In this sample, IDS/PDS tries to access PCM and RKE. In this case, you are required to provide VIN, Part Number and Serial Number shown on the screen and Outcode and Error Control for each module to obtain Incode for each module.
    4. Enter Incode for each module.
    5. Security access has been achieved.
    6. Perform immobilizer and advanced keyless functions as normal.
    2003-2007 MAZDA6, 2006-2007 MAZDASPEED6, AND ALL OTHER VEHICLES EQUIPPED WITH IPATS (PATS MODULE LOCATED INSIDE OF PCM)
    2. Confirm VIN.
    ^ In this sample, IDS/PDS tries to access PCM. In this case, you are required to provide VIN, Part Number and Serial Number shown on the screen and Outcode and Error Control for PCM to obtain Incode.
    6. Perform immobilizer functions as normal.
