Interior - Leather Steering Wheel Coming Apart
    Bulletin No.; 06-005/08
    Last Issued: 04/04/2008
    LEATHER STEERING WHEEL TORN/COMING APART
    BULLETIN NOTE This bulletin supersedes the previous bulletin issued on 04/02/08. The REPAIR PROCEDURE and PART(S) INFORMATION have been revised.
    APPLICABLE MODEL(S)/VINs
    2007-2008 Mazda3 vehicles (including Mazdaspeed3) with VINs between JM1 BK**** ** 623557 to JM1 BK**** ** 847227 (produced from August 11, 2006 to October 25, 2007)
    Some customers may experience a leather steering wheel that is torn or coming apart at the stitching, which is due to the stitching of the leather steering wheel not being strong enough. The stitching has now been improved.
    1. Verify concern.
    2. Remove the steering wheel. Refer to MS3 online instructions or Workshop Manual section 06-14 STEERING WHEEL AND COLUMN REMOVAL/INSTALLATION.
    WARNING: Handling the air bag module improperly can accidentally operate (deploy) the air bag module, which may seriously injure you. Read the service warnings before handling the airbag module. Refer to MS3 online instructions or Workshop Manual section 08-10 AIR BAG SYSTEM SERVICE PRECAUTIONS.
    3. Remove the two screws from the back of the steering wheel, then release the fastener from the front surface of the steering wheel and remove the center cover.
    4. Loosen the other two screws on the back of the steering wheel, then remove the left and right covers.
    NOTE: Remove the ground wire from the switch cover and the ground wire screw.
    5. Install a modified part and assembly in the reverse order of removal.
    NOTE: DO NOT allow the switch harness to get caught between the cover and steering wheel. Route the wire harness like it was before.
    6. Install the steering wheel with a new bolt. Refer to MS3 online instructions or Workshop Manual section 06-14 STEERING WHEEL AND COLUMN REMOVAL/INSTALLATION.
    7. Verify repair.
