And Hyundai prices themselves out of the market!
CHICAGO, Feb. 11, 2009 – Hyundai Motor America announced pricing for the new Genesis Coupe, starting at $22,000 for a well-equipped 210-horsepower, 2.0-liter, turbocharged, four-cylinder engine 2.0T model and $25,000 for the 306-horsepower, 3.8-liter, V6 engine model. Genesis Coupe will begin arriving at Hyundai dealerships later in the month.
“Genesis sedan set a new benchmark for the premium sedan segment and we think Genesis Coupe will do the same in the sport coupe arena,” said John Krafcik, Hyundai Motor America president and chief executive officer. “From our 30-mpg 2.0T with its low-pressure, intercooled, four-cylinder turbo, to the 3.8-liter Track model with 306 horsepower and Brembo® braking system, Genesis Coupe offers a wide range of powertrain and performance choices for driving enthusiasts of all stripes.”
2010 Genesis Coupe Manufacturer’s Suggested Retail Pricing
Model Engine Package Transmission MSRP
Genesis Coupe 2.0T 2.0-liter turbo 4-cyl. Six-Speed Manual $22,000
Genesis Coupe 2.0T 2.0-liter turbo 4-cyl. Five-Speed A/T SHIFTRONIC® $23,250
Genesis Coupe 2.0T 2.0-liter turbo 4-cyl. Premium Six-Speed Manual $24,250
Genesis Coupe 2.0T 2.0-liter turbo 4-cyl. Premium Five-Speed A/T SHIFTRONIC® $25,500
Genesis Coupe 2.0T 2.0-liter turbo 4-cyl. Track Six-Speed Manual $26,750
Genesis Coupe 2.0T 2.0-liter turbo 4-cyl. R-Spec * Six-Speed Manual $23,750
Genesis Coupe 3.8 3.8-liter V6 Six-Speed Manual $25,000
Genesis Coupe 3.8 3.8-liter V6 ZF Six-Speed A/T SHIFTRONIC® $26,500
Genesis Coupe 3.8 3.8-liter V6 Grand Touring Six-Speed Manual $27,500
Genesis Coupe 3.8 3.8-liter V6 Grand Touring ZF Six-Speed A/T SHIFTRONIC® $29,000
Genesis Coupe 3.8 3.8-liter V6 Track Six-Speed Manual $29,500
Genesis Coupe 3.8 3.8-liter V6 Track ZF Six-Speed A/T SHIFTRONIC® $31,000
Note: Add $750 freight charge
* Denotes mid-model year availability
Genesis Coupe 2.0T: A more efficient take on the rEAR-Wheel drive sport coupe
Standard equipment includes:
* 2.0-liter, low-pressure, turbocharged, intercooled 4-cylinder engine with dual continuously variable valve timing delivering 210 hp, 223 lb.-ft. of torque (at just 2,000 rpm), an estimated 30 mpg EPA highway rating and a top speed of 137 mph
* M6VR1 6-speed manual transmission (Optional: A5SR1 5-speed electronic automatic transmission with lockup torque converter and steering wheel-mounted paddle-shift Shiftronic® controls)
* 18-inch Euroflange alloy wheels with staggered Bridgestone Potenza RE92A tires (225/45VR18 front, 245/45VR18 rear)
* Electronic Stability Control with Traction control, ABS, Electronic Brake Force Distribution and Brake Assist
* 12.6-inch ventilated front rotors with 60mm single piston floating caliper
* 12.4-inch solid rear rotors with 43mm single piston floating caliper
* Sport-tuned MacPherson strut dual-link front suspension and five-link rear independent suspension, 24mm front stabilizer bar, 19mm rear stabilizer bar
* Front strut brace
* Quick-ratio hydraulic steering (2.7 turns lock-to-lock)
* Tire Pressure Monitoring System
* Front, side, side air curtain air bags
* Active front head restraints
* Driver’s lumbar support
* Black-out front lower fascia
* Air conditioning
* Satin silver and chrome interior accents
* Remote keyless entry system with alarm
* Leather-wrapped steering wheel and shift knob
* Power windows (one-touch up and down), door locks and mirrors
* AM/FM/XM/MP3/CD audio system with six speakers
* iPod/ USB Aux jack connectivity
* Steering wheel audio controls
* Cruise control
* Trip computer
* Projector beam headlamps with auto light control
* Bluetooth® hands-free connectivity with steering wheel controls
The 2.0T Premium model adds or substitutes:
* Power driver’s seat
* 360-watt AM/FM/XM/MP3/CD-changer Infinity® premium audio system with 10 speakers including DVC subwoofer, eight-channel external amplifier, and diversity antenna
* Proximity Key with push-button start
* Auto-dimming mirror with HomeLink® and compass
* Power tilt and slide sunroof
* Navigation system (mid-model year availability, pricing TBA)
The factory-tuned 2.0T Track model builds from the 2.0T Premium, adding/substituting:
* 19-inch gunmetal-finish alloy wheels with staggered high-performance summer-compound Bridgestone Potenza RE050A tires (225/40YR19 front, 245/40YR19 rear)
* Unique Brembo® braking system with 13.4-inch ventilated front rotors, 42mm four-piston fixed front calipers (red), 13.0-inch ventilated rear rotors, 32mm+28mm four-piston fixed rear calipers (red)
* Unique track-tuned suspension, higher-rate coil springs, higher-control shock absorbers, 25mm front stabilizer bar, 22mm rear stabilizer bar, front strut brace
* Torsen-type limited-slip differential
* Black leather bolster seats with high-friction red cloth insert
* Aluminum pedals
* Aero wipers
* Rear spoiler
* Xenon HID (High Intensity Discharge) headlights
* Fog lamps
* Lightweight temporary spare with aluminum wheel (T135/80D18)
* Note: Automatic transmission not available with 2.0T Track
Later in the model year, a tuner-focused performance model, R-Spec, will arrive at Hyundai dealerships. Genesis Coupe R-Spec is the ultimate upgradeable, affordable, turbocharged rear-wheel drive performance platform. R-Spec equipment includes:
* 2.0-liter low-pressure turbocharged intercooled four-cylinder engine with dual continuously variable valve timing delivering 210 hp, an estimated 30 mpg EPA highway rating and a top speed of 137 mph
* 6-speed close-ratio manual transmission
* Electronic Stability Control with Traction Control, ABS, Electronic Brake-Force Distribution and Brake Assist
* 19-inch gunmetal-finish alloy wheels with staggered-width high-performance summer-compound Bridgestone Potenza RE050A tires (225/40YR19 front, 245/40YR19 rear)
* Brembo® braking system with 13.4-inch ventilated front rotors, 42mm four-piston fixed front calipers (red), 13.0-inch ventilated rear rotors, 32mm+28mm four-piston fixed rear calipers (red)
* Track-tuned suspension (higher-rate coil springs, higher-control shock absorbers, 25mm front stabilizer bar, 22mm rear stabilizer bar, front strut brace)
* Air conditioning
* Remote keyless entry with alarm
* iPod/ USB/Aux jack connectivity
* Note: Automatic transmission not available with R-Spec
Genesis 3.8: 306 horsepower and standard leather interior – a new benchmark for performance and refinement in its class
Standard equipment includes 2.0T equipment, and adds or substitutes:
* 3.8-liter DOHC V6 engine with dual continuously variable valve timing delivering 306 hp and a top speed of 149 mph
* M6VR2 6-speed manual transmission (Optional: ZF 6HP19 6-speed electronic automatic with lockup torque converter and steering wheel-mounted paddle-shift Shiftronic® controls)
* Black leather seating surfaces
* Fully automatic temperature control
* Premium door sill plates
* Chrome front fascia accents
* Fog lights
In addition to 3.8 equipment, the 3.8 Grand Touring adds or substitutes:
* Unique brown leather seat interior environment
* Heated driver and passenger seat
* Proximity key with push-button start
* Xenon HID (High Intensity Discharge) headlamps
* Heated mirrors with outside turn signal indicators
* Backup warning system
The factory-tuned 3.8 Track model deletes the backup warning system and chrome front fascia accents from the Grand Touring model, and adds or substitutes:
* 19-inch gunmetal finish alloy wheels with staggered high-performance summer-compound Bridgestone Potenza RE050A tires (225/40YR19 front, 245/40YR19 rear)
* Unique track-tuned suspension, higher-rate coil springs, higher-control shock absorbers, 25mm front stabilizer bar, 22mm rear stabilizer bar, strut brace
* Aluminum pedals
* Aero wipers
* Rear spoiler
