How to: The gas mod! ie Put gas in your car
Discussion in 'Facts and How To's' started by mazdamn02, Jul 11, 2007.
  1. mazdamn02
    mazdamn02 Guest
    Hi everyone, here's my contribution to the mnmazda community!
    First of all, you must be 16 to dispense gas lawfully in the great state of Minnesota. And a disclaimer: In no way will I take responsibility if you start on fire during your fill up.
    Safety first: Don't smoke, talk on your cell phone, or play with fire while at the gas station.
    Step 1: Find money.
    Step 2: Find a gas station.
    Step 3: Find the fuel door on your car. It will probably be on the left or right side, and in some cases the rear.
    Step 4. Pull up to a gas pump leaving enough room for you to walk in between your car and the gas pump.
    Step 5: Turn of your car.
    Step 6: Get out of your car.
    Step 7: Go to gas pump and select method of payment.
    Step 8: Typically now you would select the "octane" of fuel you need. Open your gas door.
    Step 9: Remove nozzle from the pump and insert in car.
    Step 10: Engage lever to activate the fueling process.
    Step 11: Wait until it stops pumping gas or until gas starts to shoot everywhere.
    Step 12: Replace nozzle in pump. Close Gas door.
    Step 13: Enjoy your newly gassed JDM ride!
    Discuss!
  2. dmention7
    winar. Josh gets the audiolink, hands down.
    PSYCHE! THE CONTEST IS OVER, SUCKER!!!!
  3. Slim
    Slim Guest
    Hi, newbie here. I'm a little fuzzy on step 9. Should I roll down the window before I insert the nozzle into my car? Does it matter which window?
    Thanks. Any help is appreciated.
  4. Jesse MS3GT
    Jesse MS3GT Querulous
    I need help on filling my blinker fluid and changing my muffler bearings... Got a write up for that? :confused:
  5. mazdamn02
    mazdamn02 Guest
    Yes. Let Darwin do his dirty work! :D
  6. AJ
    AJ 110 HP of FURY!
