Grassroots Challenge MX6 Mafia thread
Discussion in 'Project Cars' started by concealer404, Sep 20, 2011.
  1. concealer404
    As the founding member of "MX6 Mafia," Challenge-bound for $2012, here's a current log of what's up.
    MONEY PAID
    1990 MX6 GT Turbo - $900
    2nd gen MX6 KYB GR2s - $180
    2nd gen MX6 Megan Springs - $140
    Addco sway bar endlinks - $40
    Addco 1" rear sway bar - $40
    Harbor Freight Fog lights - $15
    Prosport Boost, water temp, and oil pressure gauges - $130
    Innovate LC-1 w/ Auto Timer display - $167
    Used Moroso Catch can - $30
    HKS PFC F-Con setup - $250
    Mazda Hood bra - $10
    used Aeromotive 13109 AFPR - $50
    used WeaponR Coolant overflow tank - $20
    -AN line for catch can and AFPR - $40
    -AN fittings - $45
    1991 Probe GT w/ MSD Blaster2, TKT hybrid turbo setup, Walbro 255lph HP, EEC EBC v1.0, built head, ported and extrude-honed intake manifold - $600
    Total SPENT: $2657
    MONEY RECOUPED
    Stock suspension - $200
    A/C delete pulley - $40
    Stock Rear sway bar - $30
    Stock intake manifold - $40*
    Stock 10k mile head - $150*
    TKT turbo setup - $600
    TOTAL RECOUP: $1060 (Max allowable is $1006.)
    $2657 - $1006 = $1651
  2. mndsm
    Looks legit to me.....
  3. niterydr
    niterydr Legendary Status!
    Part out that probe and you will be in great shape!
  4. mndsm
    Probe's already parted and recouped as far as he can. The TKT setup he sold off that car brought it down to 0 as it was.
  5. concealer404
    Probe is gone....
    The big "trick" up my sleeve is that the turbo/exhaust/intercooler setup was included in the $900 purchase price.
  6. mndsm
    You know, I just thought of something. You're pretty well hosed for getting anything else into the budget, because you painted yourself into a corner by capping your selldown. no trades allowed after selldown is done.
  7. concealer404
    No big deal, i already pretty much included everything in there, even the stuff that's not installed yet. (Head and intake manifold)
  8. concealer404
    Didn't feel like making a new thread, so this thread will now be dedicated to all things Grassroots Challenge MX6(s).
    Anyways, i have one.
    I need to clean this shit up.
  9. concealer404
    Anyways, i have working heat in my junk now.
    This is probably fine, right?
    I have another exhaust leak at the turbo/manifold flange. :( Trying to decide if i want to weld it back up for once and for all, or if i want to do a custom manifold.
    Video might be happening soon.
  10. dmention7
    I bet you have more in t-clamps than you do in the rest of the car.... holy tons of couplers batman! :D
  11. mndsm
    seems legit.
  12. concealer404
    The only "kit" that was ever made for this thing was the HKS pipes, made for use with stock intercooler and stock turbo. Down the road, i'll have some nicer pimpy ones made, but in the meantime, i'm ok with this. :D
    2 hours of work, under $200 for entire FMIC setup, and pressure tested to 45psi with no leaks. Not pretty, but it gets the job done. XD
  13. EvanB`
    EvanB` New Member
    I hope you pressure tested it to 45PSI by turning the boost up that high.:)
  14. concealer404
    Haha oh man.... that poor CT26 would be hating life. :D
    Nah, just standard boost leak tester. Highest pressure i've seen on this motor while running is 25psi.
  15. concealer404
  16. concealer404
    Alrighty.... parts and numbers!!!!!
    BRAKES
    Beck Arnley branded Axxis Metal Master front pads: 088-1358M - $12.64 on Rockauto
    Beck Arnley branded Axxis Metal Master rear pads: 088-1357M - $14.32 on Rockauto
    Centric Front Rotor: 12145026 - $17.07 on Rockauto
    Centric Rear Rotor: 12145027 - $21.79 on Rockauto
    Techna Fit SS Brake lines: MA-1200 - $80.50 shipped on Ebay
    TOTAL = $163.39 + shipping + fluid of your choice for neck-snapping brakes.
    SUSPENSION
    Whiteline Rear Control Arm Bushes: W61759 - $89.91
    Whiteline Front Control Arm Bushes: W51284 - $71.91
    Whiteline Rear Trailing Arm Bushes: W61767 - $89.91
    Addco 1" Front Sway Bar: 559 - $200 on Summit
    Addco 7/8" Rear Sway Bar: 467 - $200 on Summit
    Addco Front Endlinks (pair): 012 - $14.77 on Summit
    Addco Rear Endlinks (pair): 015 - $12.28 on Summit
    Energy Suspension Shifter stabilizer bushing (trans end): 4.1106 - $5.99
    More parts to follow.
  17. AJ
    AJ 110 HP of FURY!
    did the event happen?
  18. mndsm
    It did and it didn't. The event took place, the build got pushed back due to unforseen unemployment issues with the wife. The car is currently with Ben right now to get things moving again.
  19. concealer404
    Well... I went, at least. :D
  20. concealer404
    This car is/was a clusterfuck.
    90 grill on an 88? OH GOD WHY?!?!?!?
    626 grill way better.
    More teardown. This wiring harness is awful. The fuel injectors were leaking like crazy.
    This is probably fine.
    Ugh.
    Never seen this sensor on a manual car before. Not even sure what it does, to be honest.
    Saving for future reference.
    Pretty much my least favorite thing ever. Shit's stuck.
