FS: Two Antec 300 Computer Cases!
I have two of these for sale, they are excellent cases for just about any use, plenty of room for 6-8 hard drives, plus 3 5.25" external expansion bays. Both including top mounted 140mm fans and I will throw in one addtional 120mm fan in each, there is room for a rear 120, side panel 120, and two front 120's depending on your needs.
$40 each
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
I think I'll grab one of these from you. Seems like it would be a good setup for starting a build.
Word, I am pulling mah file server out of one of them, I'll get that done in the next day or two and clean the case out. Then I can just meet you on my way home from work one day if that works. For the money they are hard to beat.
The only reason I could see not grabbing it would be if I decided to go with some combo deal off newegg. This is going to be my first PC build so here goes nothing!
Thats a mATX board meaning its smaller / has fewer slots, the case is designed to fit a full ATX board, but there is no reason you can't put an mATX board in it. The PC I have in it right now is actually a mATX board similar to that one so to answer your question, nope it'll work just fine.
alright, I have a shit ton to figure out on this cpu build, lol. No rush on the case, I'll take it when it's ready. Maybe same night you could look at the memory on the dell, with that extra stick we have?
@ Jay - GTFO lol
AJ the one case is cleaned out and ready to go, Monday is pretty much out for Me, but I'll toss the case in the car so I can hopefully setup time to stop by later in the week to drop it off and look at that memory. Still have one of these fer sale.
Werd, I know I'm working late at least a few nights this week. So I'll check the schedule as well and we'll set something up.
