Engine Controls - MIL ON/DTC P0106 Set
Discussion in '2006' started by JustROLLIN, Jan 7, 2009.
    TSB: 01-044/06
    MULTI-MODEL - MIL ON WITH DTC P0106
    2004-2006 Mazda3 vehicles with VINS lower than JM1BK******545535 (produced before June 1, 2006)
    2006 Mazda5 vehicles with VINS lower than JM1CR******129154 (produced before June 1, 2006)
    2006 Mazda MX-5 vehicles with VINs lower than JM1NC******119712 (produced before June 1, 2006)
    2003-2006 Mazda6 vehicles with 2.3L produced before August 9, 2006
    On some vehicles, the MIL may come on with DTC P0106 (MAP sensor malfunction) stored in memory due to corrosion of the MAP sensor chip. This produces a short circuit which causes the output characteristics of the MAP sensor to fall out of specification.
    2. Replace the MAP sensor with a modified one.
    3. Verify repair.
