Engine Control - Engine Stall/Hesitation After Hot Start
    TSB: 01-008/07
    2006-2007 MAZDA3 (EXCEPT CA SPEC & MAZDASPEED3) - ENGINE STALL AND HESITATION AFTER START-UP UNDER HIGH AMBIENT TEMPERATURE
    2006-2007 Mazda3 (except CA spec and Mazdaspeed3) vehicles with VINs lower than JM1BK**** ** 696694 (produced before January 1, 2007)
    Some vehicles may experience the following symptoms due to improper PCM software:
    1. The engine stalls when depressing the accelerator pedal slightly, then releasing it with the A/C on.
    2. The engine hesitates when doing a quick take-off after start-up with a high ambient temperature.
    2. Using IDS 46.6 or later software, reprogram the PCM to the latest calibration (refer to "Calibration Information" table) by following the "Module Reprogramming" procedure.
    NOTE: ^ Always update the PDS/IDS tool first, then follow on-screen instructions to download the needed calibration file for PCM reprogramming.
    ^ IDS shows the calibration part numbers after programming the PCM.
    ^ Please be aware that PCM calibration part numbers and file names listed in any Service Bulletin may change due to future releases of IDS software, and additional revisions made to those calibrations for service related concerns.
    ^ When reprogramming a PCM, IDS will always display the "latest" calibration P/N available for that vehicle. If any calibration has been revised/updated to contain new information for a new service concern/issue, it will also contain all previously released calibrations.
    3. After performing the PCM reprogramming procedure, verify the repair by starting the engine and making sure there are no MIL illumination or abnormal warning lights present.
    ^ After PCM reprogramming, it is no longer necessary to road test the vehicle to "relearn" KAM (Keep Alive Memory).
    4. Fill out an "Authorized Modification" label (P/N 9999-95-AMDC-97) with the new PCM calibration information, your dealer code, and today's date.
    5. Place the "Authorized Modification" label on the A-pillar below the tear tag in the driver door jamb. The "Authorized Modification" label will inform technicians of the PCM calibration change if future repairs are necessary.
