Drivetrain - Oil Seepage From Transfer Case
    Bulletin No: 03-001/08
    Last Issued: 01/09/2008
    OIL SEEPAGE FROM TRANSFER CASE
    APPLICABLE MODEL(S)/VINs
    2006-2007 Mazdaspeed6 vehicles with VINs lower than JM1GG12L*7*108052 (produced before July 1, 2006)
    Some vehicles may experience oil seepage from the transfer case in the location shown.
    This may be caused by insufficient cleaning of the mating surfaces of the front and rear cases before applying sealant.
    The cleaning and assembly process has been improved during production.
    2. Remove transfer case according to Workshop Manual (section 05-17 TRANSFER REMOVAL/INSTALLATION).
    3. Completely remove sealant and oil off contact surfaces and bolt holes of both case halves with Brake Clean.
    4. Apply locally sourced Permatex Ultra Grey RTV sealant to case as shown.
    5. Reinstall transfer case according to Workshop Manual (section 05-17 TRANSFER REMOVAL/INSTALLATION).
    6. Verify repair.
