Drivetrain - Front Axle Knocking Noises in Extreme Cold
Discussion in '2007' started by JustROLLIN, Jan 7, 2009.
    Bulletin No.: 03-004/08
    Last Issued: 04/11/2008
    KNOCKING NOISE FROM DRIVESHAFT WHEN TURNING IN EXTREME COLD TEMPERATURES
    APPLICABLE MODEL(S)/VINs
    2006-2007 Mazdaspeed6
    2003-2007 Mazda6 vehicles produced before Oct. 1, 2007
    2007-2008 CX-7 vehicles with VINs lower than JM3ER******188196
    (produced before Oct. 1, 2007)
    2007-2008 CX-9 vehicles with VINs lower than JM3TB******134353
    (produced before Sept. 17, 2007)
    At extremely cold ambient temperatures of -15°C (5°F), some vehicles may exhibit a knocking noise from the front drive shafts when the vehicle is moving with the steering wheel turned fully right or left. The noise disappears after a couple of minutes of driving.The grease in the outer (wheel side) joint of the front drive shaft becomes harder in extreme cold temperatures and stick-slip occurs in the joint.
    The outer joint grease has been modified at mass-production to eliminate the noise.
    2. Remove front drive shafts according to Workshop Manual (section 03-13 FRONT DRIVE SHAFT REMOVAL/INSTALLATION).
    3. Disassemble drive shafts according to Workshop Manual (section 03-13 FRONT DRIVE SHAFT DISASSEMBLY/ASSEMBLY).
    4. Wipe off old grease in outer (wheel side) joint and clean it with brake cleaner.
    NOTE: The outer (wheel side) joint cannot be disassembled, however, it can be accessed through the joint.
    5. Assemble drive shafts according to Workshop Manual (section 03-13 FRONT DRIVE SHAFT DISASSEMBLY/ASSEMBLY).
    6. Fill new boot (wheel side) with modified grease according to Workshop Manual (ex. CX-7 grease amount: 110-130 g {3.89-4.58 oz.}).
    NOTE: The new boot set includes modified grease (NGK509) for outer (wheel side) joint.
    7. Reinstall front drive shafts according to Workshop Manual (section 03-13 FRONT DRIVE SHAFT REMOVAL/INSTALLATION).
    8. Verify repair.
