DavidPHumes' turbo LSx S5 FC Swap Thread...
Discussion in 'Project Cars' started by DavidPHumes, Oct 23, 2011.
  1. DavidPHumes
    DavidPHumes New Member
    Hey guys,
    I guess this is both a "welcome" thread as well as a build thread. I've had my RX-7 since I was 17 (22 now) and last winter converted it from an auto/N/A Rotary to a 6 speed/N/A LS1. The car made just over 400RWHP. Well, my never ending love for boost has started me on a new project for this winter.
    Some background on me... I'm a 22 year old MIS major at UMD. I'm currently a Junior and am also working full time at one of the top managed IT service providers in the country providing desktop, server, and network support. My dad owns a body shop up here but I never really loved cars until a couple of years ago. I've had a few Subarus (a track ready 2.5RS, stage 2 Legacy GT Limiteds, etc.) and currently drive a "Mopar Stage 3" '05 SRT-4 as my daily. It makes about 340WHP. It's fun, reliable, and quick. Despite being a Neon I love the shit out of it.
    I've had 2 RX-7s. The red GXL you see below and a 1987 Turbo II that I sold a long time ago. I'd like to say that I've got nothing at all against the Rotary. Mine ran great until pulled. For what I want out of a car, though, an LSx really fits what I require. And yes, it still handles awesome, even with the V8. I actually dropped weight when doing the swap since I don't have AC, power steering, or heat ;) I will never sell my GXL. I will keep it until the day I die.
    The goals with this car are "simple". It's going to be a 600RWHP, 9 second daily driver that I can take my girlfriend out to dinner in, listen to some tunes, go grocery shopping, and whoop some Corvette ass. It will be tuned for E85.
    Motor:
    2002 LM7 (5.3L, iron block, aluminum heads)
    ARP rod bolts
    ARP head bolts
    LS6 cam
    Comp Cams 26918 valve springs
    Comp Cams 7.400" Hi-Tech pushrods
    LS2 timing chain
    Melling "296" high flow oil pump
    LS7 Lifters
    Lokar throttle cable
    Lokar throttle cable bracket
    Lokar engine dipstick
    LS6 Intake manifold
    Ported stock throttle body
    Fuel:
    Injector Dynamics ID1000 (1000cc) Fuel Injectors
    Aeromotive 340 "Stealth" fuel pump
    Aeromotive LS1 fuel rails
    -6 stainless feed and return lines
    Corvette Fuel Pressure Regulator
    Turbo setup:
    Turbonetics TC76 (.96 A/R, F1 turbine wheel)
    Turbosmart 48mm Pro Gate external wastegate
    Turbosmart 52mm Race Port BOV
    SSAutoChrome 24x12x13 FMIC
    2000* Jet-Hot On All Hot Side Components
    Cooling:
    26"x19" Speedway Tru-Cool GM Aluminum Radiator
    Spal 16" Electric Fan
    Custom Lower Radiator Mounts and Fan Shroud
    Drivetrain:
    ATI Racing Transmissions PowerGlide w/ undecided 3600 stall converter
    B&M Ratchet Shifter
    Granny's Speed Shop motor mounts
    Granny's Speed Shop Transmission Cross Member
    Energy Suspensions Polyurethane Transmission Mount
    Tydo Race Cars prepped Granny's torque arm setup
    Strange spool
    Strange axles
    LPW Extreme 8.8 rear cover with torsion bolts
    Extreme Duty watts linkage and brackets
    Extreme Duty lower 3x reinforced control arms with heavy duty heim joints
    Wheels/Tires/Suspension/Brakes:
    Front: Enkei RPF1 17x8.5 with Nitto NT05 (235/40/17)
    Rear: Enkei RPF1 17x10 with Nitto NT05R Drag Radials (275/40/17)
    Aerospace Components rear disc brake kit
    Moser 5/8 wheel studs
    BC Racing front coilovers
    Strange single adjustable rear coilovers
    Hawk HPS Pads
    Mazdatrix Stainless Steel Brake Lines
    AMSOIL Series 600 DOT4 Brake Fluid
    Gauges:
    Autometer 3 3/8th Speedometer
    Autometer 3 3/8th Tachometer
    Autometer 2 1/16th Voltage Gauge
    Autometer 2 1/16th Fuel Level Gauge
    Autometer 2 1/16th Oil Pressure Gauge
    Autometer 2 1/16th Oil Temperature Gauge
    Autometer 2 1/16th Water Temperature Gauge
    AEM Huego Digital Wideband O2 Gauge
    AEM 35PSI Digital Boost Gauge
    Interior/Miscellaneous:
    2002 Dodge Viper GTS Seats
    Auto Power 4 Point Race Roll Bar
    Acura TSX HID retrofits (OEM housings, 25w 4300k bulbs)
    CorkSport rear strut tower bar
    CorkSport Front Lip Spoiler
    Shine Auto Project Roof Spoiler
    Here is the car as it was with the LS1 in it:
    Here's the turbo kit:
    Intake cleaned and painted:
    Wideband/boost gauges:
    Intercooler installed:
    The top is hard mounted:
    I wanted some play in the IC, so I used these cut down rubber stops to help protect what little movement it may have (the IC pipes will hold it even more securely):
    HID ballasts mounted way out of the way (don't mine the small amount of over spray :)):
    And a view from the back:
    AutoPower 4 point installed:
    The parts car I'm going to get:
    It's not the prettiest thing to look at, but you have to look past that. It's in Cincinnati and I'll be going down to get it the first week of November.
    And lastly here is a friends' car running in the quarter. His setup is very similar to mine, although he has a bigger motor and more efficient turbo. My car will not run this fast.
    http://www.youtube.com/watch?v=vLW_zpMages
  2. DavidPHumes
    Tonight I got my front bumper trimmed for my FMIC. Here's a picture with the bumper just sitting on the car and the front lip screwed into a couple of places. Don't mind any gaps in the body, I'm just demonstrating what it should look like:
  3. mndsm
    You sir, have some serious attention to detail. I'm quite impressed with your work..... can't wait to see more. That one's already cleaner than most of the FC's I know... must be nice to have an in house body guy lol.
  4. Grappler
    Grappler Member
    Nice setup I'm not much for pistons in 7s but its a nice setup and very clean :)
  5. DavidPHumes
    Thanks for the comments guys! Yes it's awesome that my dad lets me use the shop for my project. I still have to pay for any work done to my cars though :)
    I "finished" getting the 4 link installed tonight (all by myself I might add :)). I put countless hours into cleaning all of the components up and applying liberal coats of POR-15. I've been working on it after work for the last week or so. I'm pretty happy with the outcome. I will say, the narrowed rear end makes my 275 drag radials look tiny. That may be a sign I need 315s and some 17x11s :). Anyway, here's where I'm at with it right now:
  6. Turbotalon1g
    Turbotalon1g Guest
    Very nice, i'd love to see this car.
  7. concealer404
    BEAUTIFUL car man. :)
  8. JW_SPEED3
    JW_SPEED3 New Member
    I wish I had the skill, time, resources and $$ to do something like this. Car looks clean and very well done.
  9. DavidPHumes
    Thanks for the comments guys. I am buying things as I have extra money... I will be finishing buying things come January probably and then go into final build mode.
    I plan on being at BIR events as well as down in the cities at Cars and Cafe, etc.
    I'm still trucking away at this thing.
    Last weekend I worked on the roll bar a little bit. It came with a real flimsy coat of gloss black paint that chipped easily. I'm too cheap to pay the $$ to have it powdercoated so I grinded all of the paint off and painted it with 2 coats of POR15. It turned out looking good, but not perfect. I'm OK with it though since the rest of the car isn't perfect either (some would argue otherwise but hey, I'm a perfectionist).
    I also bought a mount for my GoPro to put on the roll bar.
    I also had to trim the gas tank cover to clear the rear cover for the rear end. It turned out good after a coat of POR15 :)
    There's still 2.5" of clearance between the rear end and the gas tank... I'm not the least bit concerned in the two ever coming into contact.
  10. DavidPHumes
    Also, I am completely 100% learning as I go. Most of this stuff I have never done before.
  11. dmention7
    That POR-15 is great stuff, eh? I used it on my engine block this spring, and frankly it seems to be the most durable shit out there. Nice and thick too, so as long as you put it on liberally it covers up a lot of imperfections.
  12. JohnnyT
    JohnnyT New Member
    Definitely looking forward to seeing this come C&C.
  13. Turbotalon1g
    Turbotalon1g Guest
    F C&C, i want to see this at the track.
  14. DavidPHumes
    Haha thanks guys. It should be a fun car at the track, but that's not my principal reason for the build. Also I have never been down a 1/4 mile in my life so that will be interesting LOL. She should 60ft pretty well with the rear end and drag radials. Did I mention the previous owner did wheelies? Yeah... lol.
    The summation of my weekend:
    Here's the finished wire tuck:
    I removed the brake booster and sanded it down for paint (black wrinkle coating):
    And here's the new location for the fuse box. Ignore the long bolt - just there to mock it up.
    The whole "while I'm at it thing" is killing me, but once the bay is prepped and painted I will be a happy camper I think (also I'm going to put the motor in and turbo stuff to get my clearances right and really figure out what I'm going to do about my radiator/tranny cooler setup).
    Basically what I did was remove everything possible from the bay. My dad told me to just sand down the paint in the bay by hand with a scuffer (since the Mazda paint is a pretty good base as it is) so I did that twice. On the frame rails I had put undercoat so I had to grind most of that off which you can see... that really sucked. I also cut out the upper cross support for the radiator, as you can see. I cut it a little too much on the left side but that's OK because I'm going to weld those two pieces together for reinforcement (and do the same on the driver's side). I also cut out some of the studs in the bay that weren't needed.
    I still haven't decided what to do with all of the holes in the firewall. Part of me wants to weld in pieces and really make it clean, but if I ever need some of them in the future I'd kind of be screwing myself. I think I might make plates that bolt into plate to cover the holes. It wouldn't look as clean but it would be safe and they could always be removed if I wanted to in the future.
    I also cut the holes for my FMIC. I figured one picture was good since you all know what holes look like. The driver's side sucked because there's an existing hole there meaning a hole saw can't be used. I took my time with a reciprocating saw and grinder and it looks great. After paint I will put some U channel molding around to finish the look. I also notched the firewall for clearance with intakes, wiring, etc. With my Granny's mounts I was REALLY close before, so I figured while I was doing it (a common theme). I will bondo it up to make it look factory.
  15. DavidPHumes
    By the way, as for the track thing, it will be interesting because I only have a 4 point. I will definitely run faster than 11.49 (a similar car ran 9.2x at 149MPH) so I may never get to know my true 1/4 time unless somewhere like Rock Falls turns a blind eye lol. I'm all about safety but door bars scare me in a DD. I may look into removable door bars at some point. It would be easy to add to my current setup.
  16. mndsm
    Blast time slip, get record of it, get kicked out of track. NBD.
  17. DavidPHumes
    That's the plan... dial in 60ft all day and on the last pass just go for it.
  18. concealer404
    Yep!
    Been there, done that.
  19. DavidPHumes
    Tonight I picked up this beast. Patent pending on the engine transportation.
    But seriously, I was going to borrow my dad's dually when I said fuck that, I'm using one of the rental minivans from the shop to pick this thing out. Worked magically. The van definitely is no SRT4/RX-7 in the handling department lol
    And here's the main attraction. 2005 L33 5.3L with unknown miles. It is SUPER clean (considering it came from at truck) and I even got to check out the cylinders with a boreoscope before buying - they looked good. I paid $550 for it. I think that was a pretty good deal on my end.
  20. mndsm
    500$ for that? SOLID. Can't wait to see it in its new home.
