Body - Power Window Auto Open/Close Feature Inoperative
    TSB: 09-014/06
    2006 MAZDA6, MAZDASPEED6, 2007 CX-7 - POWER WINDOW AUTO OPEN / CLOSE AND ANTI-PINCH FEATURES INOPERATIVE
    2006 Mazda6 and Mazdaspeed6
    2007 CX-7
    The 2006 Mazda6/Mazdaspeed6 and 2007 CX-7 vehicles are equipped with "Auto Open/Close" and "Anti-Pinch" window features.
    This system requires a special "Power Window Initialization Procedure" for these features to operate~ The power window initialization procedure is performed during vehicle production, however, in the following cases the initialization procedure must be performed in order to restore "auto open/close" and "anti-pinch" operation.
    ^ Battery has been disconnected.
    ^ Power window fuse has been removed/replaced.
    ^ Power window initialization procedure was not performed at vehicle production.
    NOTE: TO AVOID UNNECESSARY REPLACEMENT OF THE POWER WINDOW MAIN SWITCH, ALWAYS PERFORM THE "POWER WINDOW INITIALIZATION PROCEDURE" BEFORE REPLACING ANY POWER WINDOW RELATED PARTS.
    1. Turn ignition to ON position.
    2. From driver's seat ensure window lockout switch is NOT depressed.
    3. Press window switch down to fully open door window.
    4. Pull window switch up to fully close door window; hold switch up for two (2) seconds; release switch.
    5. Move to front passenger seat and repeat Steps 3 - 4 on passenger window switch.
    6. Mazdaspeed6 Only: Move to rear seat and repeat Steps 3 - 4 at left and right rear seat window switches.
    7. Verify proper window operation using each door switch.
