Body - Excess Liftgate Operating Effort
    Body and Accessories
    09-014/04
    2002-2003 PROTEGES - UNUSUAL NOISE AND/OR
    EXCESSIVE EFFORT REQUIRED WHEN OPERATING
    LIFTGATE
    2002-2003 Protege5
    Some customers may experience an unusual noise and/or feel that excessive effort is required when operating the rear liftgate. These conditions may be the result of a lack of lubrication in one or more liftgate damper stay(s) ball joints.
    The replacement damper stays have been modified to prevent the recurrence of these conditions.
    2. Inspect rear liftgate damper stay(s) ball joints for binding.
    ^ If binding is found, replace both sides with modified parts according to Workshop Manual (section 09-11 LIFTGATE REMOVAL/INSTALLATION).
    WARNING :Removing the damper stay(s) without supporting the liftgate can be dangerous. The liftgate may fall and injure you. Open the liftgate fully and support it before removing the damper.
    3. Verify repair.
