07-005/03 2001-2003 Protege, 2002-2003 Protege5 A/C SWITCH LIGHT GOES OUT AND/OR FLASHES WITH FAN CONTROL SPEED IN NUMBER 2 POSITION APPLICABLE MODEL(S)/VINS 2001 - 2003 Protege and 2002 - 2003 Protege5 built prior to 12/2/02 and with VINs lower than JM1BJ2***3*150990. DESCRIPTION Customer may experience warm air from the dash vents when operating the A/C system with the fan control speed set in the number 2 position for long periods of time. This condition may be caused by the improper logic within the heater control unit. The heater control unit has been modified to correct this concern. Customers having this concern should have their vehicle repaired using the following repair procedure. REPAIR PROCEDURE 1. Verify customer concern. 2. Remove and replace the heater control unit with a modified part according to Workshop Manual (section 07-40 CLIMATE CONTROL UNIT REMOVAL). 3. Verify repair.
